Hugo + Nait XS2 / SN2
Posted by: ThatsNotMyNaim on 08 October 2016
Hello,
I'm just wondering if anyone uses a Hugo with their XS2? And if so, do you find it a little bass light / a bit shallow?
I'm using Innuos Zenith (WAVs) > Hugo > Chord Shawline RCA > Nait XS > Chord Odyssey > Proac 118.
I know my Proacs have no bass boost which doesn't help but lovely speakers. I found going from Chord Rumour to Odyssey I lost a bit of bass but Rumour was muddy.
I'm thinking of a SN2 upgrade for more slam/authority? How much more slam will I get vs XS2?
I tried NAC A5 but felt it a bit dry. But now I have my system in a much better place may be worth revisiting.
Posted on: 08 October 2016 by Moussa
I used to run Mojo which is very similar to the Hugo with XS-2 with a Hicap DR and it wasn't bass light at all. Keep in mind that my speakers were Neat S1 which are amazing in their bass response. I then upgraded to the SN2 and the bass got tighter and the sound stage is wider and higher. However, the improvement from the XS2 to the SN2 is not that big so I really advise you to audition both and then you decide if the SN2 is worth the extra money.
Posted on: 08 October 2016 by ThatsNotMyNaim
Thanks Moussa. I'll bare this in mind. I actuallt borrowed an SN2 but one channel didn't work. Will have to wait and see.
Posted on: 08 October 2016 by Iconoclast
Moussa posted:
What did you replace the Mojo with?
I replaced it with Mytek Brooklyn and have it powered by a LPS (Uptone Audio JS-2).
ThatsNotMyNaim posted:
Just to highlight one point. I only used my XS2 with the Hicap DR which lifts its performance significantly and makes it close to a naked SN2. Maybe a naked xs2 vs a naked SN2 would reveal greater contrast than what I have experienced.
Posted on: 08 October 2016 by Chag...
FWIW you might be better off with light than with boomy basses. I love ProAc for their accuracy and density of timbres, texture and presentation but the lower spectrum of their floor standers is often difficult to drive and control.:]
Chag -
Posted on: 09 October 2016 by Iconoclast
Iconoclast posted:
Moussa posted:
What did you gain with the Mytek? I haven't heard the Mojo yet but despite all the rave reviews I read between the lines and interpret that it's excellent and excellent VFM for a portable DAC/HP amp but not necessarily as excellent when compared to full sized DACs in a home system.
Chag... posted:
Chag -
Naits have a bit of a midbass bump which is why careful matching is important. I thought I had bass issues with Proac stand mounts in my room until I tried B&W CM5s2. Very musical but totally unruly bass in my untreated 9x17' room. Even worse with added PSU.
Save
Posted on: 09 October 2016 by Moussa
Iconoclast posted:
Iconoclast posted:
Moussa posted:
The main improvements were bigger sound, punchier bass and increased transparency. You get more of the micro dynamics. It excels on DSD which is played native so no need to do DOP like in the case of chord Dacs which puts less processing on the cpu.
Posted on: 10 October 2016 by Mayor West
Hi ThatsNotMyNaim,
I went from Nait XS1 + Flatcap XS (Haven't heard Nait XS2) to SN2. The main reason being was that I felt the Nait XS just lacked a bit of bottom end control over my PMC 20.23's. I loved the Nait XS though so was reluctant to upgrade, but pleasingly for me the SN2 retained everything that I loved about the Nait XS but took it all to the next level. I'd say that they both have a very similar character, but SN2 has (sorry for the hi-fi clichés) superior control and slam however at the same time offers greater transparency, delicacy and soundstaging. Despite the clichés, the thing I love the most about it is that its so involving, especially when used with a good source. It will definitely be worth an audition once you've optimised the rest of your set up.
Posted on: 10 October 2016 by ThatsNotMyNaim
Mayor West posted:
Hi ThatsNotMyNaim,
Thanks Mayor. The delicacy and slam sounds ideal!
