Disabling Bluetooth on Muso
Posted by: jasons on 09 October 2016
hi all,
As title really!
i know it can be set up with a password etc but is there any way to disable Bluetooth completely?
cheers
Posted on: 10 October 2016 by ChrisSU
I don't have a Muso, but if it's the same as for the other Naim streamers, in the app, go to Settings > Input Settings and turn off the Bluetooth input from there (maybe along with any other inputs you don't use.)
Posted on: 10 October 2016 by hungryhalibut
I don't think you can turn it off, nor can you turn off any other inputs. It would be good if you could.
Posted on: 10 October 2016 by jasons
Hmmm thought that might be the case.
Maybe something for future firmware version?
