Powerline Lite
Posted by: Tariqv on 13 October 2016
Hi, I'm about to pull the plug (no pun intended!) on a new Powerline (EU type) but I'm having second thoughts due to the announcement of the Powerline Lite. Is there any info about this new product? Do you think I should wait for it first before taking the plunge?
Posted on: 13 October 2016 by hungryhalibut
It will be available next year and cost about £100, according to the blurb about the new Unitis. Clearly it's not as good as the existing Powerline. As to whether you should wait in order to get something less good, that's your decision.
Posted on: 13 October 2016 by wenger2015
Powerline lite £100. Powerline £500.00+ I think your question is answered...
Posted on: 13 October 2016 by Adam Zielinski
Tariq - with that level of equipment, as per your list, I would not skimp on few PowerLines. You will immediately notice their impact.
Posted on: 13 October 2016 by Tariqv
Thanks for your responses, ordered it today, hopefully will have a listen as early as tomorrow
Posted on: 13 October 2016 by Emre
Hello tariqv are you in Istanbul?
Posted on: 13 October 2016 by Finkfan
Totally agree with everyone. Now, do Naim have a Superlumina Powerline in development???
Posted on: 13 October 2016 by HiFiman
wenger2015 posted:
Or stick with standard supplied naim mains lead
Posted on: 13 October 2016 by hafler3o
Tariqv posted:
Yes I think you should wait. Remember 'foreign' powerlines have a different (non-bouncy!) mains plug [furutech last I looked] so they are not that similar. I asked a while back about where the "tech - lite" would appear in the powerline lite but got no reply. If it is 'all' in the mains plug end (not the IEC end) it may be of no benefit to overseas customers.
Posted on: 14 October 2016 by sharik
Tariqv posted:
but why? so disappointed by its performance?
Posted on: 14 October 2016 by Tariqv
Emre posted:
Yes
Posted on: 14 October 2016 by Mayor West
Not sure what the Powerline Lite is going to be like I found the Powerline to be surprisingly good upgrade for SN2. Very impressed with it.
Posted on: 14 October 2016 by Finkfan
Not sure but I'd imagine just a lighter version, maybe plastic of some sort?
Finkfan posted:
My guess would have been that 'Lite' was more referring to the performance of the cable but I suppose it could be anything!
Yeah I should imagine that's true also.
Posted on: 14 October 2016 by Emre
Tariqv posted:
Emre posted:
Yes
Nice to have another member from istanbul, drop me a line sometime, i just ordered 2 powerlines from extreme audio, are you shopping from them?
Found the Powerline in Izmir actually from Dukkanhifi. I haven't been able to decipher how to PM you, apologies to other forum members
Posted on: 14 October 2016 by Richard Dane
To ensure there's no solicitation of members, there's no private messaging here but you can post to another member's  wall.
Posted on: 15 October 2016 by Tariqv
So initial impressions, with the PL on the NDX...Had the chance to listen to a few songs yet, songs that I know well. First thing I immediately noticed, lower noise floor. The sound is slightly more focused and notes slam harder (more definition in audio-speak?).
On the negative side the treble has become quite tiresome, any idea why?
Posted on: 15 October 2016 by Finkfan
Give it a change to burn in, I'm sure it will calm down
Posted on: 15 October 2016 by Adam Zielinski
Tariqv posted:
Tariq - give it a while to settle down. PowerLine calms the performance of the component it is connected to. If trebble continue to be problematic, have a look at: interconnects and speaker positioning in the room. You may have to adjust your speakers' toe-in angle or move them by few centimeters.
Posted on: 15 October 2016 by Mayor West
I got my powerline s/h and it still took a day or two to settle so I'd give it some time.
Posted on: 15 October 2016 by Emre
Are they any difference between us/eu/uk powerline performance wise?
Emre posted:
Not that I know of.
Actually the key design element is the component-side plug.
Posted on: 15 October 2016 by hafler3o
Emre posted:
As the UK and foreign mains plugs are different (no decoupling tech in the overseas ones) there will be a difference (as the tech that is supposed to 'make the difference' isn't there in the overseas plugs). Whether that difference translates into a performance' differences is in the ears of the beholder.
Adam Zielinski posted:
Tariqv posted:
Thanks for the tip Adam; been listening for several hours, the treble is not as bad as it was before but still not completely settled down. Do you suggest that I increase toe-in or decrease, whats the rule of thumb to decrease the harsh treble effect?
