Photobucket woes
Posted by: dayjay on 14 October 2016
Anyone having any problems with photobucket? For.the last week or so I am only seeing placeholders where my pics should be. This applies on my s7 edge and ipad. I've deleted the app and reinstalled and even set up new accounts to no avail. Any assistance welcome!
Posted on: 15 October 2016 by Gianluigi Mazzorana
Did try them all but no way i could make it work. Moved to flickr.
Posted on: 15 October 2016 by Bert Schurink
Hi David - I had this problem before like you for months. It was quite annoying as one need to first check photos to see what you upload. However since I got my iPads on IOS 10 it works again, the app is just a bit sluggish. So in case you haven't upgraded yet, that might do the trick.
Posted on: 15 October 2016 by Pcd
Same as Dayjay seems useless.
