Album art again
Posted by: Osteoclast on 21 October 2016
Hello,
I still cannot get my album art working in the app. Ripped a Cold Play album...did not work. Can see the image jpg after the track list. Tried to empty image cache in the app. Still dead. Anyone out there with a distinct suggestion?
Since
Sincerely, Thomas
Posted on: 21 October 2016 by supmario
Once the files are located in NAS you mamy try to reindex them.
Posted on: 21 October 2016 by David Hendon
Sorry but I haven't been following your travails. Can you remind us how you are ripping, what you are storing the rips on, what app you are running and on what device?
A suggestion in the dark as it were, but for Naim apps, the artwork needs to be called folder.jpg or cover.jpg   I don't think image.jpg will work....
best
Posted on: 21 October 2016 by Adam Zielinski
Most likely metadata issue on the tracks.
Posted on: 21 October 2016 by hungryhalibut
If you could program the app not to play Coldplay's execrable music you might be onto something marketable..... more seriously, you need to explain very clearly what exactly you are, or aren't, doing. If the files are FLAC and have embedded cover art, or if a jpeg called folder.jpeg is include in the album folder, the art will show, so long as your upnp server is set up correctly.
Posted on: 22 October 2016 by nickpeacock
Supmario's solution is the one I also recommended. Which NAS drive do you have? If Synology then go to the control panel and find the re-indexing feature.
Posted on: 22 October 2016 by Mike-B
If a re-index doesn't work - & assuming you've cleared both app caches - then its something in the metadata & this means you have not set up whatever ripping program you're using correctly.
