There and back again – NACA5 to SuperLumina and back to NACA5
Posted by: Adam Zielinski on 26 October 2016
Been playing around with speaker cables between my two Naim systems.
I was always impressed with SuperLumina speaker cables – one of the early adopters. The level of details they present is simply stunning.
Recently during some box swapping and moving I thought I would try my trusted NACA5 on a ‘better’ system (NDS /252 /250DR into Ovators S-400).  Suddenly fun returned.
Don’t know what to attribute it to.
But it surely cannot be due to this cheaper garden-hose lookalike thing…
Or….???
Posted on: 26 October 2016 by gary yeowell
Or it actually could be. My findings from trial with the stuff, exactly.
Posted on: 26 October 2016 by Adam Zielinski
gary yeowell posted:
Glad to see I'm not the only one
Posted on: 26 October 2016 by Allan Milne
Thank you Adam, thank you, thank you
... this could save me a fortune
Allan
Allan Milne posted:
Allan
Certainly saved me - I actually had a second SuperLumina set at home for a 2 week demo with my main system. Put my NACA5 again last night and fun returned. And a smile - imagine how much music (or as my dealer calls it - software ) I can buy with that money.
Posted on: 26 October 2016 by ken c
Adam Zielinski posted:
Or….???
did you notice this reduction in "fun" the very first time you installed the SL speaker cables? i assume they replaced the NACA5?
enjoy
ken
ken c posted:
Or….???
enjoy
ken
Correct - I've done it twice now. SL certainly did bring increased resolution - it does sound fantastic. But somehow NACA5 sounds fun. It seems to open up mid-range too.
Posted on: 26 October 2016 by Mulberry
If I remember things right, Jon Honeyball posted something along that line a few weeks ago.
interesting... i dont have SL speaker cables (yet?) but when i can afford them it would be interesting for me to see if i experience same in my system...
a sense of "fun" is critical to my enjoyment of music, but of course, as we know, "fun" can mean different things to different people...
how long did you use the SL cables before you decided to switch back?
enjoy
ken
Posted on: 26 October 2016 by jon h
its what ive found. But other people might disagree, which is fine.
as i said before, SL speaker cable is *streets* ahead of NACA5 in every single area. Except one, which is the musical timing.
If you find all the other attributes to be beguiling, then great. I couldnt live with SL as I have heard it because I wouldnt end up listening to my system.
But... remember I am used to 6x135+DBLs which focus like a laser beam on timing.
ken c posted:
I've had them in my music room on and off for around 8 months. Even tried a second set of SLs from my dealer - had it for 2 weeks on a home demo.
Tried both SL and NACA5 with my two systems connected to Ovators S-400 in the same room. Same conclusions.
ken c posted:
are you using SL DIN XLRs?
enjoy
ken
ken c posted:
ken c posted:
enjoy
ken
Nope - Chord Tunned Aray. Interconnects: SL for NDS to 252 or TQ Black Diamond for nDAC to SN2).
jon honeyball posted:
yes, i remember you mentioning this some time ago. are you able to say how one would detect "poor timing". i assume this defect shows all music material -- in which it will be easy to pick up. or does it only manifest with certain pieces?
enjoy
ken
would you also describe the lost sense of "fun" as poor "timing" ?
enjoy
ken
ken c posted:
enjoy
ken
Not sure if it's timing. When I think about it it's more down to presenting music as an organic whole in case of NACA5. With some music SL somehow could appear to be over-analytical.
But it's nuances...
Posted on: 26 October 2016 by Ardbeg10y
ken c posted:
enjoy
ken
In my humble opinion, yes. Timing is the most essential part of music. By far. This is one of the things our students learn on conservatory and is the distinction between avarage and good. 'Fun' as one would say.
Same counts for hifi I came to learn when I joined the naim society a year ago.
Posted on: 26 October 2016 by varyat
Did the demo- Naca5 stays.
Posted on: 26 October 2016 by TOBYJUG
If you could long term trial the full loom perhaps the " fun" will return but more " funnier " no ??  When I see some ducks all flying in a row it always looks and sounds as if they're having fun.
Posted on: 26 October 2016 by ryder.
"Not sure if it's timing. When I think about it it's more down to presenting music as an organic whole in case of NACA5. With some music SL somehow could appear to be over-analytical." I can imagine what you are saying. In summary, there is less detail and separation with the Naca5. The Super Lumina is more detailed and better separated. As the detail and separation of the Super Lumina are better, that will translate to analytical. Music will sound looser with the Super Lumina. On the other hand, the Naca5 sounds more organic and "together" since there is less separation. It can be a case of personal preference and also system matching. I am not sure if the speaker cable is more amp-dependent or speaker-dependent. I suspect the Super Lumina will sound better if matched with warmer and less detailed speakers.
ken c posted:
enjoy
ken
But it's nuances...
Thanks Adam -- i understand what you mean...
enjoy
ken
Ardbeg10y posted:
ken c posted:
enjoy
ken
interesting. still not sure i fully understand how i can tell if a piece of music exhibits poor timing. when i used to play in a brass band, i recall an obvious aspect where a musician would start playing a little too early or too late. of course, it is almost impossible to play precisely "together", but the musicians should maintain a sense "coherence". with excessive incoherence, music, to me anyhow, sounds uncomfortable, stressful,  to listen to.
But extra clarity of reproduction could highlight the fact that its natural for musicians no play 'not exactly together'.  Its also interesting to try to understand what poor timing means for a solo artist -- rubato -- where the artists exercises some rhythmic freedom...
sorry, its evident i don't really know what  i am talking about...
enjoy
ken
for me, it was classic "PRAT". SL just didnt make my foot tap. I adore everything else it does. But it doesnt make my foot tap in the way that NACA5 does. This was on context of NDS/500DR/300DR etc system.
What would happen on my 52/6x135/DBL system I have no idea. But im not prepared to spend that much on speaker cable -- there are downsides to a 6 monoblock active system :-) But remember that said 6x135/DBL is incredibly revealing, and took to the S1Pre with huge gusto.
jon
if i was spending money, it would be on superlumina interconnects and the Allegri preamp.
is there a superlumina for preamp output on phono to snaxo? I thought we were still waiting for snaxo SL cables? Or maybe I'm wrong. Again.
ken, come listen some time. I can show you easily.
ryder. posted:
food for thought ryder -- i think i see what you mean. i agree that system dependence could be a key factor too. but i still would like to be able to experience a piece of music and be able to assess the timing issue in isolation -- and be able to say - that's well timed or poorly timed.  of all the groups i have seen live, some good some bad -- never felt for the bad ones that timing was the issue. for the good ones, i could hear a lot more than i hear from my hifi system -- any reproduction system that gets close to that is a good thing in my view.
or, is "poor timing" an artifact of reproduction systems?
enjoy
ken
