ND5 XS
Posted by: Wals79 on 29 October 2016
hi guys, anybody else had issues adding radio stations through naims radio portal to their streamer?
Ive selected the ones i want to add multiple times etc as instructed yet my streamer will not retrieve them and store them, anybody got any ideas?
thanks in advance
What control point are you using ?? iOS or Android app or just the remote ???
Not sure I understand what you are trying to do, unless you are trying to add stations not listed in the many thousands included with the Naim iRadio service.
Mike B im running ios control. The radio stations can be added direct from the pc almost as a favourites list to the nd5 via its mac address apparently and store them direct. My streamer does not have the dab module fitted so only fm and am/mw for me most of the stations i want are listed on the site and i can store them on the pc portal just cant get them to the ND5? I dont use it that often for internet radio but if i had all my favourites on the pre stored list im sure it would encourage me more
PC portal???
ND5XS is managed either via a remote control or a tablet with a NAIM app running. All inputs including radio stations can be managed that way.
I don't bother with loading stations from PC, the Naim iRadio (vTuner) service has all I need (+ 10,000 I don't need) that are all viewed from the app & I just load them as presets, its is just so-o much easier than messing with PC stuff.
On the iOS app I keep the ones I use all the time as "Presets" which is a function of the app, you just select the station & touch the star in the middle of the bottom banner, that turns the star (in outline) to filled in (solid) & it becomes a Preset on the iRadio front screen. (see the att pic) If I want another station thats not on my presets, then I go searching the so easy station listing ..........
Also I would add that iRadio HD (320kbs) & (UK only BBC HLS) on iRadio are really good, better top end extension & fuller bass than with FM, although FM beats all for mid range detail & realism.
I shall try it this way and see how i get on, thank you for the pointers
