Plugging Order of Equipment On A Power Strip / Extension Block
Posted by: ryder. on 29 October 2016
I have read about the deleterious effects of power strips that come with a glowing red light and an on/off switch. Unfortunately I am currently using one, an MK Duraplug power strip that has the red light and on/off switch. The exact model of this extension block I currently have in the system is as shown below.
I will be getting the Wireworld Matrix 2 power strip soon and would appreciate some advice on the plugging order of equipment on this thing to optimise the performance of the system. I used to have the NAP 250 DR connected directly to the wall outlet since the power strip has a long cord (4.0m or 5.0m cord). With the soon-to-be Matrix 2 power strip, the NAP 250 DR cannot go to the wall outlet and will have to go into the power strip.
I have read about the putting the source, considered as the most important component, closest to the socket of the power strip, and the least important component at the end of the strip. However, this was assuming the power amp is not connected to the strip but to a dedicated wall outlet. What if the power amp goes to the power strip as well? I would appreciate some thoughts on the plugging arrangement below, whether it is considered acceptable.
1. NAP 250 DR
2. Chord QBD 76 DAC
3. Krell KPS-30i CD player / transport
4. Hicap DR (feeding the NAC 282)
5. NAPSC
Any advice would be appreciated.
