Ripping
Posted by: fathings cat on 30 October 2016
How would I rip an audio DVD so my unitiserve serv can see it and play to my NDS?
I fancy listening to Floyd quad mix of DSOTM from the immersion set on my main system.
regards
Gary
Posted on: 30 October 2016 by garyi
Well the serve wont recognise the format for a quad mix, so forget that. I assume the dvd has a 5.1 audio sound track to deal with that. So home cinema is your best bet I guess.
Posted on: 30 October 2016 by Harry
I don't think you can rip a quad mix as quad. For stereo there are a few possibilities. I use DVD Audio Extractor HD.
