NAC A5 terminations
Posted by: Simon Lovell on 13 November 2016
Can anyone recommend the best place to get my speaker cable connectors soldered?
Posted on: 13 November 2016 by Simon Lovell
I live in Salisbury and have the cable
Posted on: 13 November 2016 by Pcd
A dealer should be able to carry this out if not a good electrician.
Posted on: 14 November 2016 by joerand
Pcd posted:
I'm not sure how much soldering an electrician - good, bad, or otherwise - does these days. They mostly use wire nuts and other more reliable mechanical connections.
Any hi-fi dealer that sells speaker cable in bulk ought to be up to the task of soldering terminations. I have to suspect there's one in the greater Salisbury vicinity.
Posted on: 14 November 2016 by Richard Dane
If you're in Salisbury then your nearest Naim dealer is probably Audio T in Chandlers Ford.  They should be able to properly solder your speaker connectors to your NACA5.  Give them a call.
Posted on: 14 November 2016 by Christopher_M
Winchester Hi-Fi. Pick up a couple of decent bottles at Toscanaccio too. (Both are closed on Mondays).
C.
