Remote issues
Posted by: Richieo on 16 November 2016
Hi All,
For info my current system is a CD5i-s, NaitXS with a FlatCap XS, and a pair of ART Emotion Monitor speakers.
Whilst it sounds great (the speakers in particular are very special) i am having some issues with the remote control.  Basically it works fine for the CD, but the volume control doesn’t seem to work with the amp.  I have tried switching the mode by pressing the “rec”, “sub”, “pre”, “tun”, and “cd” buttons and these seem to work as I can switch the remote off of CD mode.  However none of them seem to get the volume buttons, mute button or the input selector working for the amp.
Is there a reset function, or some button combination I need to press to get the volume buttons working again?
Any thoughts would be appreciated.
Richard
Posted on: 16 November 2016 by hungryhalibut
Enter 'reset remote' into the search...
