Trying to understand flashing source "mute" button on NAC282
Posted by: Graeme MacArthur on 18 November 2016
I only use one source input on my NAC282 - "Tuner" to connect my ND5XS. I also have my Headline 2 plugged into the "Tuner" output socket. Normally I have the "Tuner" output for the headphones muted. The pre-amp is only one month old.
When I want to listen through the headphones I take the "Tuner" output out of mute. Sometimes this causes the tuner source mute button to flash. The manual says that this indicates a power supply or link plug fault. The first time it happened I remade all the connections and it seemed to have cured the issue. Today it happened again. If I press the source mute button while it's happening the source does mute, but keeps flashing. I think it stops by itself after a while. I say "think" because I press mute on the IR handset and amplifier front in an attempt to get it to stop and perhaps it's something to do with this.
I read in these forums that it may just indicate that the pre-amplifier is stabilising, although I can't find anything to suggest this in the manual.
Can anyone shed any light on this for me please?
