wall shelves?
Posted by: sjw on 25 November 2016
I know its not ideal but does anyone know who sells wall shelves that are deep  i enough to fit naim cd5 etc  ie front of shelf to wall
many thanks
Posted on: 25 November 2016 by ChrisSU
All manufacturers I've looked at publish dimensions on their websites, so it should be easy enough to find out. HiFiRacks make custom sizes to order if you can't find one that suits.
Posted on: 25 November 2016 by hungryhalibut
I'm reading Johnny Marr's autobiography and he mentions the Queen is Dead photo session. Apparently the one used on the cover and as your avatar was marked by him not to be used because he is peering out from behind Morrissey, but the record company ignored him anyway.
As to shelves, anything that takes an LP12 should take a CD player I'd have thought.
Posted on: 25 November 2016 by sjw
yes it was the one he didn't favour apparently...but Morrissey had apparently already chosen and it had been sent off to press.
I got a Proof of the album sleeve shortly after -  the postman had merely bent the envelope in half to fit through the letterbox!
I'm after more 'domestic' hifi shelving..
cheers
Do you really, really want a wall shelf? Will a stand not do?
really really.......
Thanks but I want a shelf not an expensive hifi Shelf
Just a deep bookshelf...and I thought someone may know?
Posted on: 25 November 2016 by Dungassin
In that case, why not go the cheap route and get a couple of large angle brackets from B&Q or other DIY store, an appropriate sized piece of wood (or thickish MDF?) and make one yourself?  After all, that's how I mounted the big TV in my study, although i will admit that I didn't just fix the brackets directly to the wall, but put a pair of wooden battens onto the wall and the fixed the brackets to them., thus keeping the back of the shelf a short distance from the wall, allowing for easy positioning of cables.
