Superuniti optical connection to TiVo box
Posted by: Dalamtian on 28 November 2016
What, if any, optical cable do I need to connect my Superuniti to my TiVo box ?
Thanks in advance,
Nick
Posted on: 28 November 2016 by james n
A standard toslink cable will do fine.
Posted on: 28 November 2016 by wrc
If you have anything else connected to the tv, like a blue ray / DVD player, Xbox etc. or if your tv is a smart tv with apps for Netflix / Amazon etc... then it makes sense to connect the superuniti to the tv and not to the TiVo.
Posted on: 29 November 2016 by Dalamtian
Thanks for the replys,WRC didn't think of that good shout.
Nick
Posted on: 29 November 2016 by Richard Dane
Just be sure that the TV digital out is set for 2 channel PCM rather than multichannel bitstream - the DAC in the Superuniti is 2 channel only and not multichannel compatible. It may be set like this by default but otherwise it should be changeable via the menus.
