Attenuator plugs/ cables/ devices between Naim DAC and amp - Low volume level listening
Posted by: Disposable hero on 30 November 2016
Due to neighbourly concerns it is not possible to listen at the preferred 'louder' levels and therefore only low to moderate volume levels. This presents a problem in that the volume adjustment at the start end of the pot is not precise and sometimes there is something missing in the overall musical performance. The music just comes across better when being able to adjust the volume between the range of 9 o'clock to 11 o'clock. This would become too loud in my system and due to aforementioned neighbourly concerns not a good thing to do. Possibly by having some line attenuation between DAC and amp this could be resolved? The past discussions on attenuated interconnects have been looked at here on the Naim forum, these are based on some Russ Andrews types which were not well regarded. Alternatively there are in line attenuated RCA plugs of varying values, -10dB to -20 dB, or boxes for in line adjustments using dial control. This should allow the desired volume range to reside further away from the stop-point of the pot, to be around 9 o'clock to 11 o'clock. However this would also mean not using the typical 5 pin DIN and having to resort to RCA interconnects. It would be good if future amplifiers (like the Nait XS) will feature the newer designs of volume control, rather than potentiometer as the trend seems to be what will appear on the new Uniti models?
Are there solutions along the lines of attenuator plugs/ cables/ devices between Naim DAC and amp that you are using and could recommend, without being detrimental to the sound quality and musical presentation?
