Naim and Foobar
Posted by: JSH on 14 December 2016
Hi
I rather like Foobar as my upnp server(?).  It's quick and easy.  However with the Naim  ( Android) app I can't get it to display artwork, like Asset does.  I've trawled the Foobar site and though there are hundreds of add-os I cant find one which does this
Does anyone know how to do this?
Many thanks
Posted on: 15 December 2016 by Huge
Looks like Foobar_upnp is FooBar'ed.
How are you keeping the Album Art, as a separate JPEG, or embedded in the tracks?  Try doing both
Have you tried using different file formats (FLAC, WAVE, ALAC, AIFF etc)?
Posted on: 15 December 2016 by JSH
Thanks.  I've tried saving as both separate jpegs and as embedded in the metadata.  No difference and no difference between WAV, FLAC and MP3 either
Posted on: 15 December 2016 by ChrisSU
Does Foobar have a setting to rescan your music library?
Thanks.  It does but re-scanning hasn't made the artwork appear so far
