Cleaning speaker cones
Posted by: Hal on 18 December 2016
Last year I moved in to a dusty environment. Blower cannot do the trick for mid bass woofers. Thinking of a damp cotton cloth but I do not want to mess with treated - paper things. Speakers always remain their grilles off.
Any suggestion?
Posted on: 18 December 2016 by Stephen Tate
Vacuum cleaner with a brush attachment on the end?
That's what I use, works a treat, just don't use the high settings if too OTT.
Posted on: 19 December 2016 by james n
Soft paint brush.
Posted on: 19 December 2016 by TOBYJUG
+ ΒΌ Soft paint brush. Also those microfibre cloths. Also Hoover on very low suction over cone area
Posted on: 20 December 2016 by Pev
Some dub reggae at extreme volume works for me! I actually use the phrase "just blowing the dust off the speakers, dear" .
Posted on: 20 December 2016 by Hal
Pev posted:
Posted on: 20 December 2016 by Wugged Woy
A camera lens cleaning brush or one of those brushes usually included in LCD TV screen cleaning kits. Perfect :-)
Posted on: 23 December 2016 by Loki
Wugged Woy posted:
Blow, don't suck. Camera brushes often have a little 'puffer' on the end to do the job. Alternatively, blow through a straw.
