Uniticore - first impressions of sound quality and app interface
Posted by: J Saville on 20 December 2016
Last night I had the pleasure of being able to compare the newly arrived uniticore to a unitiserve SSD on a reference level Naim system.
The reference system consisted of:
NDS, 2x555ps, Statement S1 pre-power, S-800s, full fraim rig, unitiserve and core in rig, netstreams switch also power lined. External HDD with Chord Sarum Super Array USB, Chord Music Ethernet from Server to switch.
So the first thing we did was power up the core, which immediately prompted us with a firmware update. This was fine, and after no more than 5 minutes the core was up to date and ready to database. Then we plugged in the external HDD, which was loaded with around 6000 albums. The core started databasing immediately, with music appearing real time. It should be noted that it takes a wee while with that much music, and it still hadn't finished databasing by the time that we had finished listening at around 10pm...
In terms of the interface, the core showed up immediately in the new app. It is very easy to configure, with local music storage as well as network shares/stores able to be configured from the iPad. We didn't jump too far into this however as we were mainly interested in how it sounded, so we just let it database what we already had available.
I have to say that Naim have absolutely nailed the interface. You now get artist cover art. It grabs a cover from the album folder within, in the case of more than one album per artist it generates a collage from all coverart from every album! Very clever work here, really impressed.
So down to business with the all important listen. We started with the core, queued up a track by Angus and Julia Stone. I have to say it sounded absolutely fantastic. I haven't heard this system offer such a sense of rhythm. Naim have certainly build a Naim box here!
We then switched back to the unitiserve, simply unplugging the Ethernet and USB cables and switching them over to make testing fair. Hit play on the same track, and... It just felt a bit off. The unitiserve has always sounded better to me than other upnp servers running on other hardware, but now it just sounds a bit disorganized. The bassist is checking his watch to see how much of the gig he still has to play, the drummer keeps nodding off. Hmm.
After this the unitiserve was immediately unplugged and removed from the stack, and didn't get a look in for the rest of the evening.
We did further testing on the core, and a big step up in sound actually came from removing the unitiserve PSU from the loop. Clearly the switch mode power supply wasn't helping things!
What I found most interesting about the whole thing was that suddenly I wanted to buy one, where previously I was content with minimserver running on my readynas. The unitiserve was always cost prehibitive to me, but the core is in my eyes an absolute bargain. A core is now most definitely on my list, right after a new unitinova, which I'm hoping are not too far away...
Well done Naim, 5 and a half stars out of 5.
Posted on: 20 December 2016 by Stefan Vogt
Wow, thanks for this! Did you also check the Core's digital output, e.g. on the NDS input?
Cheers, Stefan
Posted on: 20 December 2016 by J Saville
We didn't, as we didn't have a dc1. I would expect it to sound better as in my experience improving the power supply on the transport makes a big difference!
Posted on: 20 December 2016 by ChrisH
The first review! Nice work and interesting findings, look forward to hearing more once the Core gets its feet under your table.
Posted on: 20 December 2016 by Adam Zielinski
Most interesting! Thank you for this summary.
Posted on: 20 December 2016 by Pcd
Glad I've got one on order looks as if it's gonna be a late Christmas present ?
Well worth the wait!
Posted on: 20 December 2016 by Bert Schurink
Thanks for the detailed and interesting report. I guess it will land on quite some wish lists...
Posted on: 20 December 2016 by Chag...
Thank you J. You mention an external HDD; what was the local drive databasing in the UC caddy? HDD or SSD?8/
Why not running the US with an alternative linear power supply? :]
Chag -
No drive in the core so far. We may do further testing as to which sounds better, internal HDD vs external, and may play with ssds at some point. It's not my system to do things with, so who knows what will end up happening there!
I believe the owner tried a long dog PSU but returned it due to it not sounding as good prat-wise as the standard serve PSU. Can't say I've ever been impressed with the TP PSU for serve, and I have experienced serves not booting when powered by them. Switching back to the serve PSU allows them to boot up just fine.
Guys - you will get moderated for this alternative PSU discussion
The most important thing is - Core is here and it's cheaper than UnitiServe and seems to work better.
Posted on: 20 December 2016 by Noogle
Anyone know what the fundamental differences are between Unitiserve and Core?  Presumably it runs Linux?  What's the CPU?
I believe it's an arm based CPU. Also uses a Naim built PSU with a toroidal transformer. It seems to run very cool with no storage on board.
Posted on: 20 December 2016 by Innocent Bystander
Next thing to try is the Core's rendering capability - i.e. SPDIF out into the NDS, as opposed to network connection: how do they compare?
that will be of interest to people with various other systems.
Posted on: 20 December 2016 by Simon-in-Suffolk
Noogle posted:
The new Uniticore also runs Naims new embedded customised Linux build which will appear in the other other new Uniti products which I had the pleasure of listening to a a few weeks ago at Naim.. and very good they performed too.
Be interesting to compare SQ wise the Uniticore with my reference ReadyNAS 102 - ReadyDLNA UPnP media server which sounds and measures as the best media server I have tried on UPnP with Naim.. (all to do with interframe timing consistency on TCP data transfer bursts of the media as I have reported on this forum previously).. I suspect and hope it will be similar, but with new improved Naim UI. Great initial feedback from the OP.
I understand a planned big SQ improvement area will be with the Uniticore SPDIF out, where the new powersupply and internal decoupling should really pay dividends.
S
Posted on: 21 December 2016 by t@rmac
Innocent Bystander posted:
yes...... very interesting......
Posted on: 21 December 2016 by james n
Is this a fully in house developed solution or built on an existing platform - i think the original server products were built on the DigiFi platform and customised for Naim ?
It looks like Naim have listened to customers feeback and come back with a nifty solution - Nice work.
Posted on: 21 December 2016 by Richard Dane
James, I gather it's Naim's own in-house solution.
Thanks Richard - looks really good.
Posted on: 21 December 2016 by Paul Donovan65
I'm really interested in this thread & thanks for posting it. Please excuse my lack of knowledge but I have a quick  question. I currently have a muso and also have an order in for an atom and core. My current upnp server is a qnap 210 and apologies if I've got this wrong but it sounds like I will get an improvement in sound quality over the qnap when I start using the core. Is this correct as I thought that the upnp just gave the track to the source such as the muso or the apollo and the sound quality happened there? I'd really appreciate any advice.
Posted on: 21 December 2016 by Noogle
Paul -
This is a highly contentious subject.  There are at least two schools of thought.  I am a "bits are bits" fundamentalist and believe it wont make a blind bit of difference which digital server you use.  Then there are those who say "let your ears be the judge", who can hear the difference between different digital components.  You pays yer money and you takes yer choice.
Noogle
Posted on: 21 December 2016 by J Saville
If you look at a music server as being like a CD transport, it starts to make more sense. Would a cd555 sound as good with a cd5i transport?
I was also in the camp of 'bits are bits', but then my ears told me different. I played the same file (a non-naim rip I might add) from asset upnp installed on a laptop, and then on a unitiserve, and the unitiserve had a much better sense of timing. The only thing that held me back at the time was cost.
And now that the core is here, sounding better again and at half the cost, I'm screwed...
Posted on: 21 December 2016 by Ian F
Paul,
As Noogle says, this is a contentious issue.  I have a UnitiServe which has needed to be sent to Naim on two occasions for repair.  Whilst away, I have used the Netgear Ready DLNA server software pre-installed on my NAS to listen to my music.
The difference between the two is readily audible on my system; is one 'better' than the other? Difficult to say, as one person's 'better' is another's 'different' or 'worse' but I prefer the way the UnitiServe presents the music.
Perhaps I will 'prefer' the way the Core presents music, if and when I get to hear one.
Ultimately, as is always the case with these things, it will be up to you to decide whether you have a preference, based on what you hear, or not.
Ian
Posted on: 21 December 2016 by Simon-in-Suffolk
Noogle posted:
Paul -
Noogle
 This is not at all contentious, certainly  in the audio engineering world. Bits are abstractions.. and bits are bits is simply over simplified  marketing mumbo jumbo, we are dealing with physical values in time and quantity as well as cross talk and alien attributes such as noise.. If you are happy with cheaper transports that make many more cost  and subsequent engineering compromises then use a Sonos transport or AppleTV. For those that appreciate that the transport integrity is key to the performance of the  connected down stream systems then they will continue to invest in quality transports... but contentious it certainly isn't it... it's a simple choice.
Posted on: 21 December 2016 by Allan Milne
Lets not turn this into a "bits are bits" argument again ... that's for another thread, lets keep this one on the Core.
... I have just deleted a couple of paragraphs to follow this request ... since I don't altogether agree with Simon but, as I said, leave that to another thread.
Allan
Posted on: 21 December 2016 by TOBYJUG
If it could replay DVDs, we would be sure if that drummer was really nodding off.
