Where did Tidal search go?
Posted by: EnataiDan on 20 December 2016
Upgraded to IOS v5.0 and the search function in Tidal has vanished (it's not on the "T" menu in the upper right like in used to be).  Can someone point me to where it went?
Thanks,
Dan
Posted on: 20 December 2016 by spurrier sucks
Pull down or top right on home screen.
Posted on: 21 December 2016 by nigelb
I can't see the Tidal search on a pull down but of course it is there when you touch Home. Either way, this is the wrong place for it. The more intuitive location for Tidal search should be when you touch the Tidal icon like it was on version 4.9 of the App.
If this change was intentional then I think it is a retrograde step.
Otherwise 5.0 is working fine here but I feel for those who are experiencing problems.
Posted on: 21 December 2016 by EnataiDan
Thanks - found it (but putting it on the main home screen of the Naim app is the last place i would have looked).  Seems odd that it's been move out of the Tidal section w/in the Naim app itself.
Oh well, just my $.02.
Thanks,
Dan
EnataiDan posted:
Thanks,
Dan
Agreed!
Posted on: 21 December 2016 by R.K
EnataiDan
It is in Tidal. Just pull down and a search bar appears.
OK got that now. You need to go into My Music, select Albums and then you can pull down the search bar.
Not as obvious as before, hence one or two of us hadn't noticed it.
Posted on: 22 December 2016 by EnataiDan
Yeah - thanks Naim.  Looks like they recognized the issue and fixed it in v5.1 that just came out today.
Posted on: 22 December 2016 by Reburner
Are there any change release notes released anywhere? I'm all ok now but it took me a while to work a few things out.
I found this: https://forums.naimaudio.com/to...m-app-ios-update-5-1
