Naim Uniti not picking QNap/Minimserver since software update
Posted by: Robert Daoust on 25 December 2016
Hi, my Naim Uniti not picking QNap/Minimserver since software update. Any ideas? Robert
Posted on: 25 December 2016 by Harry
Have you switched it off, switched off the network back to the router and switched them back on, one at a time, from the router outwards, allowing each device a couple of minutes to initialise? This often does it and it's a step which needs eliminating before becoming too concerned.
Posted on: 25 December 2016 by Bart
Every few weeks my NDS doesn't 'see' my server.  A quick power cycle of the NDS is all that's needed.
Posted on: 25 December 2016 by Adam Zielinski
What did you upgrade? Naim firmware or QNAP firmware? MinimServer software?
Posted on: 26 December 2016 by DrPo
Out of curiosity does any one else have the issue when powering cycling a NAIM streamer having the "fault 36...." message appear on screen? I am avoiding to power off my NDX as when I do I need 3-5 power cycles without the dreaded "fault 36.." appearing... my NDX is powered by an XP5 PS but I don't think this has anything to do with the fault message. The streamer is running latest beta FW.
