Cannot delete folder in Naim app
Posted by: Stover on 28 December 2016
I have experiented and ripped some files from Mac to Synology NAS? I have now deleted the music files from the NAS by using the Mac, but the music folder won't dissappear from the Naim app. (containes no music).
How do I refresh or delete the folder? Thanks in advance.
Stover
Posted on: 28 December 2016 by Klout10
Hi Stover,
Probably, you have a mediaserver running on your NAS (e.g. Minimserver, Asset, Twonky) the Naim app is only displaying what is served by the mediaserver. So probably, you'll need the mediaserver to do a 'rescan' ...
Hope this helps ... Michel
Posted on: 28 December 2016 by Mike-B
   Clear both the app cache(s)in the app settings dropdown menu.
Posted on: 28 December 2016 by Stover
Edit. I found and cleared cache, and it did work.
Great, thanks a lot Mike B
