Super Lumina Lengths in an active system
Posted by: Audioneophyte on 28 December 2016
Can I run a shorter pair of SL cable to one speaker and then a longer pair of SL cables to the other?
Thanks Team!
Posted on: 28 December 2016 by Audioneophyte
PS... EDIT:  Technically I know I "can" do it...  the question is... Is there a drawback?  will the sound be degraded in anyway using two different SL cable lengths?
Posted on: 29 December 2016 by wenger2015
You should have both sides the same length, just gently fold the cable on one side if necessary.
One of the main reasons is to do with inductance and capacitance,  if you do a forum search you will find a number of threads on this subject with some excellent well explained answers.
Posted on: 29 December 2016 by Richard Dane
Always stick to same lengths to left and right channels.
Posted on: 29 December 2016 by tonym
Yep, the perceived wisdom is to keep them the same length. But circumstances did require me to try different lengths on my second system, and I really couldn't tell the difference compared with same-length cabling. I did  read the other day that with a 10M (30') length discrepancy the difference was 33 nanoseconds, the same difference as having one speaker less than a human hair's thickness away from the other one. If you can hear this then you're a better man than me!
Indeed, there'll be a difference in the inductance and resistance, but it'll likewise be insignificant , and inaudible. Are you suggesting this discrepancy is likely to damage Naim amplifiers?
Posted on: 29 December 2016 by Allante93
Well, first off, Merry Christmas!
2nd and most importantly, key words.
SL Speaker Cable
 552 Active System
Common sense
Resale value, best to keep the lengths equal, at least in pairs.
""Apart from Naim's own upgrade cable - Super Lumina - alternative speaker cables cannot be  recommended by Naim, however, should you still wish to try them then you should ensure that the cable is low capacitance and of moderate inductance.  High capacitance cables are to be avoided at all costs and may result in damage to your amplifier.
NACA5 specifications are as follows:
Capacitance:         16pF per metre
Resistance:          9 milliohms per metre
Inductance:          1uH per metre
Minimum length:     3.5 metres per channel
Maximum length:    20 metres per channel (note that longer lengths can be used up to around 25 m but then some small signal loss must be expected)"
We can eliminate the Maximum length, common sense.
Optimal performance 5-10 m.
Vs
Minimum length 3.5 m
If I was fortunate enough to own an Active 552 System, I would lean towards optimal performance @ 4 m, and dare anyone to hear the difference between 4 & 5 meters.
However, resale value of SL Speaker Cable would demand equal lengths.
 JMHO
Allante93!
