nac52 inputs
Posted by: jon h on 30 December 2016
just been poking around the input boards on my nac52 - couldnt remember what i had fitted when it went back for full service and pots8 etc at the factory a while back
looks like all inputs are line level except for the last one which is variableIMG_6329
Posted on: 30 December 2016 by Paul Quigley ie
With the CDS you will not need the variable input.  I suspect you will get a better sound without it and the other one?
Posted on: 30 December 2016 by jon h
its only on input/output 6 which is not in use. Might see if i can get a pair of straight through boards for it
Posted on: 10 January 2017 by jon h
The very lovely Tom Tom have a set of straight through boards which will kindly swap for the variable ones. Excellent service thanks.
Posted on: 13 January 2017 by jon h
which have arrived today - i shall fit the boards, and post the variable ones back to him. Superb service as always from Mr Tomtom
