Airplay in Win7 Itunes is not working
Posted by: Dy2k on 04 January 2017
I used to be able to use the Airplay in itunes in Win7 to stream music from from PC to MU-SO.
However, it is not working for somehow reason. I can still see the Airplay logo and my MU-SO in the Airplay drop-down menu, but after selecting the MU-SO, the sound still comes from my PC speaker, not the MU-SO.
I have my win7 itunes updated, it doesn't help.
The airplay feature in my MACBOOK and IPAD works perfectly fine with the MU-SO.
Anyone knows how to solve this problem? Many thanks.
Posted on: 05 January 2017 by Guy007
PC Reboot ?
In the iTunes Airplay, does the Mu-so have a + or Tick to the right ? Is the message underneath showing connected, or offline ?  Is the volume slider at half or more for the Mu-so ?
If you deselect the PC speaker tick, does that trigger the music to the Mu-so ?
Are you using Apple routers ? There was a recent firmware update, not sure if it's related tot he iTunes update.
