Fault 61
Posted by: juanito on 09 January 2017
I just cycled the power on my ND5 XS as it had lost the connection to the LAN and now I get the following message:
Fault 61
BridgeCo init fail
Any ideas what this is and if it is possible to fix it?
Posted on: 09 January 2017 by sjbabbey
Searching the forum turned up this:
https://forums.naimaudio.com/to...1-bridgeco-init-fail
This suggests your ND5XS may need to go back to naim for a fix/repair.
Posted on: 09 January 2017 by juanito
Thanks - interesting that I've had similar issues - loss of WiFi, loss of UPnP access - ever since the ND5 XS was new, two or three years back.
Posted on: 09 January 2017 by David Hendon
I would suggest you drop an email to support@naimaudio.com and see what they think.
best
Posted on: 09 January 2017 by ChrisSU
juanito posted:
Once you have had your streamer repaired, bear in mind that you may have issues with network setup, especially if you are using WiFi. Maybe worth having a look at this when you set it up again??
Posted on: 15 January 2017 by juanito
'got my ND5 XS back from the dealer - it seems the software was corrupted and needed to be re-loaded.
Now I just need to reprogram all of the settings
