Headphone Question
Posted by: mikeybaby on 09 January 2017
I am trying to connect headphones to the tape out on my 202. So I have an adapter--
DIN to 4 RCA (2in and 2out) going into the 202 DIN
I thought the "out" would work with my headphones but the "in" worked for a while and now neither one works
What am I doing wrong?  Thanks
Posted on: 09 January 2017 by thebigfredc
I have never heard of anybody connecting their phones directly to the fixed line level output of the tape out. The conventional approach would be to use a headphone amplifier between your naim preamps tape out and your headphones which would allow you to adjust the volume.
Ray
Posted on: 10 January 2017 by mikeybaby
...and boom goes the dynamite!!!
Posted on: 10 January 2017 by Richard Dane
thebigfredc posted:
Ray
Headphones are traditionally connected to a pre-amp through the fixed level output of the Tape Out and then into your headphone amp.
Mike, the DIN5-4 RCA Phono tape interconnect should work fine, but you need to be ensure it's connected correctly - IIRC on Chord's interconnect the Red and Black are Tape IN and Yellow and Blue are Tape OUT from the preamp.
Posted on: 10 January 2017 by thebigfredc
Difficult to know from Richards reply whether he is condemning or condoning my post.
Either way I am standing by my advice to the OP which is it is not normal behaviour to connect  a pair of HPs directly to a preamp.
Ray
Posted on: 10 January 2017 by Pcd
thebigfredc posted:
Ray
Likewise always used  Project Headphone Amp on my 82 worked a treat.
