Splitting contacts of Naim Nac A5
Posted by: hifinerdwannabe on 11 January 2017
I would like to connect my Nac A5 speaker cables to a non naim power amp. However, the plugs of the Naca will not fit and I wonder if it is possible to separate the contacts/plugs going in to the amp by sawing through the plastic without destroying the internals of the cables?
Posted on: 11 January 2017 by trickydickie
You can just pull the pins out of the plastic housing without the need to deface anything.  Retain the housing for when you get a proper power amp!
Richard
Posted on: 11 January 2017 by ChrisSU
Just remove the black plastic box using the single screw on the back. I would recommend covering the exposed parts with heat-shrink tubing if you do this.
Posted on: 11 January 2017 by hifinerdwannabe
Thanks! I have not noticed that there is a screw on the back but will check this out as soon as I get home.
I also want to point out that I do have the proper, modern plugs that can take modern speaker cables on my amp, it's just that the plugs on the amp sit narrower than those of the Nac A5
