Converting AIFF to Wav or MP3
Posted by: El Guapo on 29 July 2011
I've been given copies of a radio program in AIFF format and I would like to listen to them on my MP3 player. I don't have a Mac or an IPod so I need to copy them to WAV or MP3. Any suggestions on a conversion tool - I found some on google but I'm not willing to pay $70 to convert 6 files
Posted on: 29 July 2011 by Alfa4life
If you don't have a mac I assume you have a PC so the process will be the same, install iTunes (free) add the aiff files to library with import settings set to MP3. If you then look where you itunes library is (My Music > Itunes > Itunes Music) you should see the MP3 files.
Posted on: 29 July 2011 by El Guapo
Wow thanks. I did not know you could do that
Forgot to mention, make sure in preferences that you set the option to 'copy files to itunes media folder'
