Uniqute USB problems
Posted by: Goodeyeclosed on 07 August 2011
Hi everyone,
When using a USB drive I have been unsuccessful in listening to music. What format does it have to be?
Any tips to troubleshoot?
Posted on: 07 August 2011 by garyi
What kind of USB drive, it needs to be powered by the mains and not from the USB socket.
Also are you able to see any music or nothing at all?
Wav or FLAC is what you want.
Posted on: 07 August 2011 by Goodeyeclosed
Nothing shows up.
If it needs to be powered, does this mean I can use a flash drive?
I meant can't.
Posted on: 07 August 2011 by Trevor Wilson
Hi
The most common issue here is that the unitiqute needs the USB stick to be formatted in fat32 or fat. We do not support ntfs or hfs.
I tried Fat and Fat32. Will it work with a flash drive? It is Unpowered.
