How to identify Naim speaker cables?
Posted by: naka on 17 January 2017
How can we distinguish a white NAC A4 from a white NAC A5?
Somebody sold me a pair of white cables printed in black "naim audio" plus a direction arrow on the side (and not between the cables) as used NAC A5.
Did the A4 ever had the printed marks on the side?
Thanks once again for the help
Posted on: 17 January 2017 by Richard Dane
Yes, NACA5 used to have printing on the edge rather than between the conductors.  Trouble was it would often eventually rub off if the cables were moved around a lot.  Otherwise it is the same as it has always been.
NACA4 and NACA5 are easy to tell apart mainly because the sheathing is totally different - NACA4 is reasonably pliant whereas NACA5 feels harder to the touch and is much stiffer - more like nylon than PVC.
Posted on: 17 January 2017 by ChrisSU
A5 is really stiff, stick some under your jacket and go to a football match and you'll be arrested for carrying an offensive weapon. A4 is flexible.
Posted on: 17 January 2017 by Ardbeg10y
Since I'm about to buy Nac A5 too, is there fake Nac A5 on the market? I mean serious amounts of Chinese produced fake?
Posted on: 17 January 2017 by sheffieldgraham
Ardbeg10y posted:
If  your really concerned by it from a NAIM dealer.
sheffieldgraham posted:
Ardbeg10y posted:
I'm not really concerned indeed, I have a proper Naim dealer who gives good advice.
This morning I suddenly ran into a pair of fake B&W 800 series speakers. It was pretty bizar - I've informed B&W.
So that is the background of my post - I understood the doubt one can have.
Posted on: 17 January 2017 by TOBYJUG
Ardbeg10y posted
Be careful out there, they have been known to lurk around corners and supermarket aisles.
Posted on: 17 January 2017 by james n
TOBYJUG posted:
Ah the new Focal range...
Posted on: 17 January 2017 by b_lund
And better looking than ever
