Empty Fraim Shelf - The Gods are Looking After Me
Posted by: Bart on 18 January 2017
WIth the boxing up of my never-used-anymore CD player, I have an empty Fraim shelf. Top to Bottom:
NDS - EMPTY - SN2 - HC2 DR - 555 DR
Emailed my local dealer as the empty shelf was sending me subliminal messages all day.  Dealer only has a 272 and SU in house.  (They sell little Naim; mostly Spectral and other high current stuff.)  The Gods were looking after me.  Nothing to demo . . .
Posted on: 19 January 2017 by Moussa
Maybe it's meant to be like that and having an empty shelf under the NDS may not be a bad situation
Posted on: 19 January 2017 by nigelb
I hear Naim are coming out with an empty Naim black box designed specifically for those empty Fraim shelves and will be called the No Naim. It has extraordinary isolating properties that stops all the nasties from power supplies and transformers entering the delicate electronics of your Naim source.
It is rumoured that a DR version of the No Naim will be available soon and the No Naim non DR version will be upgradable. Even fresh air will be upgradable to DR fresh air in due course.
So Bart, before you get too smug, assuming your dealer can get hold of a No Naim, you do indeed have something to demo after all.
Posted on: 19 January 2017 by Ardbeg10y
Silence and space should be appreciated more:
Ardbeg.
Posted on: 19 January 2017 by Bert Schurink
Bart posted:
...that' zen, you would just get stressend out boy upgraditis after hearing a new black box...
Posted on: 19 January 2017 by Cat lover
That's space for another 555ps for the NDS.
Posted on: 19 January 2017 by Bart
Cat lover posted:
Doh I didn't think of that -- ha ha!  Naa won't go in that direction.
I was "up" for some home auditioning, but tis not to be as none of the 3 dealers within a 50 mile radius of my home have any separates in house.
I'll have to wait for that No Naim empty black box to hit the North American distributor.  Speaking of which Manu hasn't posted in a long time; hopefully he's just busy.
Posted on: 19 January 2017 by nbpf
Bart posted:
The headphones output of the SN2 is not very exciting, is it? What about a headphones amplifier? This would also leave you plenty of space on the shelf for a Raspberry Pi + hifiberry pro feeding the NDS via SPDIF. In a No Naim box, this combo could be aesthetically acceptable, I believe.
Posted on: 20 January 2017 by yeti42
Can't any of your dealers borrow a 282 and a 250 from the importer for you to listen to? They're just not trying.
Posted on: 20 January 2017 by analogmusic
the empty shelf - is calling out for a 282.
Posted on: 20 January 2017 by Bart
nbpf posted:
Bart posted:
I never never never listen with headphones at home.  Something about it doesn't work for me -- I get uneasy being so "isolated."  I have an irrational fear that someone will walk into the room and startle me.   I listen that way on an airplane fine  . . . but never have taken to 'phones at home.  Weird, I know.
yeti42 posted:
They could I'm pretty sure . . . I've thought about asking . . .
Posted on: 21 January 2017 by rsch
Cat lover posted:
Posted on: 21 January 2017 by Bart
rsch posted:
Cat lover posted:
Sure, I COULD. But at this point clearly the SN2 is the weaker of all the elements; not that it's weak in its own right!
I might see if the distributor will 'lend' a 282 and 250Dr to my dealer; that way I can try with my existing HiCap DR
Posted on: 21 January 2017 by DrPo
Well a 282 250 made a very noticeable difference in my home vs my current SN2 level amp during a recent demo - even with a much lower caliber source than yours...
Nature abhors the Void !
Posted on: 22 January 2017 by nigelb
Bart, make sure your finances are in order before listening to the 282 & 250DR. It is a stonking combo and will sing beautifully with your NDS. I know from personal experience.
I had this exact source/amp combo but used a SupercapDR on the 282 (as I was planning to move on to a 252). But I am pretty confident however your HiCapDR is all the power supply you will need.
Let us know if you are able to borrow them and what you think.
The void is beckoning!
