iRadio Presets not appearing on NAC-N 272
Posted by: haggis999 on 21 January 2017
I have set up a handful of radio presets via the Naim app on my iPad but have not yet found a way to make these visible on the display of my NAC-N 272. Is this possible and, if so, how can it be done?
I was also a little disappointed that the radio presets on the Naim app are presented as a scrollable vertical list that can only show a maximum of 7 stations at a time (with only 5 on the first page). Is there no way to have a grid of icons that crams far more stations onto the screen? Such a layout would be much more practical and also look a lot slicker.
Posted on: 21 January 2017 by haggis999
I've just found that the Naim remote control has a button marked Presets, but I was actually hoping for an option on the front panel of the 272.
Posted on: 21 January 2017 by Mike-B
Have you found that pressing the remote 'Preset' twice brings up your Preset list on the front panel display  ???   Thats about as good as it gets,  all a bit clunky. iPad is the way but I get your point on the way the screen display is spread out.
Posted on: 21 January 2017 by ChrisSU
Mike-B posted:
You have to press it twice? Once seems to work for me. Not that I really use it, I don't see the point when the app has it all there in your hand.
ChrisSU posted:
My NDX is press twice to open up to scroll the presets,  but like you, my remote sees the light of day about once a year ..........  as I say in my post "iPad is the way"
I agree haggis999 comment on the preset screen layout - I've raised it on beta,  but there's bigger fish to fry in that part of the world at the moment.
Mike-B posted:
ChrisSU posted:
Are we talking at cross purposes here? If I press the Presets button once, I see presets. If I press it again, they disappear.
One press of the Preset key on the remote causes my 272 to display what station is currently playing. A second press brings up my list of presets.
Like others have said, I would prefer to avoid using the remote, but the iPad is not always the quickest solution (you have got to go and find it for a start). I would therefore like the 272's front panel to also offer me my list of iRadio presets.
A further check shows that it only takes a single press of the Preset button if the 272 was previously on another input.
ChrisSU posted:
Not so much at cross purposes Chris,  just not being detailed enough:
If the NDX (or whatever) is not playing anything, pressing the remote 'Preset' brings up the loaded preset list on the screen,  from there you can browse & select a station.   But again starting from the player not playing anything,  if you touch the preset button to show the preset list,  then do nothing & press again, the screen goes off.
If the player is playing something, even when its loaded to play but the amp is playing another source, press the Preset button & it shows the station thats playing, a 2nd press shows the Preset list & allows select (change station) & play,  a 3rd press is off
