Remote Control for Nait 3r
Posted by: Jimmy Jazz on 25 January 2017
Hi everyone, this is my first post on here for a long time.
I have recently acquired a Nait 3r, which is not responding to the remote control. It appears that there has been a leaking battery in the remote control unit at some time in the past.
Does anybody know whether an alternative or universal unit will work with the nait?
Jim
Posted on: 25 January 2017 by Richard Dane
Jim, the NAIT 3R uses Philips RC5 codec so any regular Naim Narcom, Flash, or R-Com should work just fine.
Posted on: 25 January 2017 by Toe
Jim,
If the batteries have not corroded the terminals too badly, try prising the remote apart. There is only a circuit board inside, which the back of the buttons contact when pressed.
The copper contact area was contaminated with an oily film. I got mine working again by cleaning the circuit board contact area with a clean dry cloth. Worth a try.
Posted on: 25 January 2017 by Jimmy Jazz
Thanks Richard and Toe. I will try pulling it apart first.
Jim
Posted on: 27 January 2017 by Jimmy Jazz
Success! Well, partial success anyway. I can now change volume and select the cd input. More cleaning will be necessary.
Jim
Posted on: 27 January 2017 by sheffieldgraham
Jimmy Jazz posted:
Jim
I've found that some remotes have a "rubber" moulded key pad. Each key has a black area under the key. I think this is a graphite or conductive impregnated compound that over time becomes coated with "dirt". A good rubbing with propanol or contact cleaner on this and the circuit board contacts can rejuvenate the key function. When you press the key pad it completes a contact with the circuit board contacts underneath the key.
Thanks Graham
Jim
