Core Experience - Tidal Push?
Posted by: Wm. on 27 January 2017
Had a chance to play around with the new Uniti Core last evening. Let me first say it sounds fantastic, looks amazing, and I think overall it is a great value.
One interaction gripe; if you access content on the UC, through a 272, and you select by artist or album, etc.. you are first met with "Other Albums Available on Tidal" and "Other Artists You May Be Interested In", and then, only after you scroll down through this tree is your personal content shown. This, to me, feels invasive and almost like advertising within the software. I couldn't find anyway to disable it (unless you fully disable Tidal on the 272). As I already have Tidal integration on my device, I don't appreciate the duplication (I understand some devices may not) . This interaction does not occur if you access the UC device directly, but then you can't play music unless it is directed to the analog output.
Anyone else experience this? Frustrating. Any plans to make this optional?
