Which input?
Posted by: Bikewithnonmae on 28 January 2017
Simple question, I've just picked up an NDS, which DIN input should I plug it into on my Supernait? The HDD or an Aux input? Does it make any difference?
Posted on: 28 January 2017 by Klout10
Don't think it will make much difference, but if I were you I'll plug it in the HDD input ...
Posted on: 28 January 2017 by Bikewithnonmae
Thanks I'll give it a go. I didn't know if one of the inputs was "optimised" for the streamer
Some forum members report audible differences with certain equipment, but I can't recall this happening with the SuperNait ... wonderful combo by the way! What speakers are you using?
Posted on: 28 January 2017 by NickSeattle
Default automation settings expected my NDX to be into Aux1.   Implied guidance from Naim, maybe. You can override any way you like.  I left mine there.
Nick
Posted on: 28 January 2017 by Adam Zielinski
Any input will do. I used CD, Tuner, Aux - no diff.
