tv - sound
Posted by: grahambateman on 29 January 2017
hello all.
Hope you can help.
I am trying to get my tv sound to go through my hi fi.
Current set up. Naim 122x 150 and dac.
I have linked the tv via toslink into the naim unit , but cannot seem to get the sound through the hi fi.
I changed the set up on the tv  to hi , but as
yet no luck.
Is there a simple fix please.
Graham
Posted on: 29 January 2017 by Finkfan
Hi graham. What Tv do you have? What dac?
Posted on: 29 January 2017 by MDS
You might need to go into the set-up menus on the TV and get it to output to PCM. Mine feeds my nDAC via optical lea fine that way
Posted on: 30 January 2017 by nickpeacock
TV output to pcm solved it for me too. Let us know if this works.
