Naim muso - App wishes
Posted by: me.oprinz on 30 January 2017
Hello Naim-users,
i am recently a proud member of a naim muso. Best! I am very happy.
I have some ideas on how the app would be better:
- a widget for ios (enable/disable muso, louder/quiter, silence on/of), switch entrance - important!
- change the radio apps via drag & drop (change order by moving)
- a global search or a search with an country, ... for radio stations by name
The most import is a volume normalizer. If a have digital, bluetooth, airplay - if i switch the volume has always changed manually. What i mean, is, that i can say in % (- or +) on how the volume will be changed (for the other entrances), if i switch. i come from radio to digital (which is quieter), so it has to increase x% automatically. if i switch back it should not go. there is need of some kind of history. i want that the volume of all entrances is nearly the same. this should be possible.
one more question: is it normal, that muso don't wake up on optical cable? airplay works. newest firmware 1.5.
Greetz
Stephan
