Hi, having recently activated my Credos (wow). I am now looking for my next upgrade. My current system,
Credos, Nac 72 with Flatcap Nap 90x 2, Ixo, and CDS. Recently serviced and recapped.
I suppose what I'm saying is, do I exchange fo my Flatcap for Hicap, or do I look at my power amps.
My room is about 14ftx12ft and I only have to go to about ten to with the volume control for it to be at its best volume.
Cheers Mike
Posted on: 31 January 2017 by hungryhalibut
The 72 was never designed to be used with a flatcap. So the first thing I'd do is get a Hicap for it. I'd then try a passive 250 against the active 90s. If you still prefer the latter, swap the IXO for a snaxo and Hicap. After that, turn to the power amps.
What I meant was that when the 72 was designed, the Hicap was its partner. The flatcap came later. It can of course be used, but it's not ideal.
Posted on: 31 January 2017 by ChrisSU
I'd agree that a Hicap would be a good next move, but - if you're buying old kit like that, your choices will largely be dictated by availability of good used units, so if a suitable power amp comes along at the right price, I would be tempted to grab it while you can.
