SimpleAudio roomplayer HELP! (ok it is not a Naim product)
Posted by: djh1697 on 05 February 2017
Please! does anyone know where i might download the iOS application, or better still the Android application for the roomplayer? The links on the simpleaudio website do not work and there is no app in the 'app store' on itunes
Posted on: 05 February 2017 by sktn77a
Haven't got a clue.  Have you tried Googling it?
Posted on: 05 February 2017 by hungryhalibut
As Simple Audio are no more, the app cannot be downloaded. The only option seems to be to get it from someone, or a former dealer, who still has a copy. Google search, very useful it is.
Posted on: 05 February 2017 by garyi
Not sure how you would get that over to your IOS device though, jailbreaking or magic I guess.
There was a thread on the forum a while ago. Someone got the app from a dealer I believe.
Posted on: 05 February 2017 by Huge
On Android you can directly load the .apk file (when you've found a source for it that is!).
Posted on: 06 February 2017 by sktn77a
Huge posted:
But you can't get n-Serve............   (Sorry, I'm beginning to sound like a broken record!)
Posted on: 08 February 2017 by djh1697
Managed to get the Andriod app, all i seem to be able to do is control the wolume. Maybe i'll get a Windows tablet, the Windows application works fine, however, my PC and Roomplayer are in different rooms. I have an inexpensive streaming system in my bedroom, so it can't be all bad!
Posted on: 09 February 2017 by djh1697
I have obtained a windows 10 tablet, there are some software issues, but it is working fine now, thank you!
