Naim iOS App 5.4 Problems
Posted by: juanito on 13 February 2017
Ever since I upgraded the iOS App to version 5.4, I see the following two problems:
When opening the App, it finds my ND5 XS and then says that it cannot connect because another App is already connected (or words to that effect). This doesn't happen every time I connect and is fixed by re-trying once or twice. I am the only user of the App.
When using my NAS UPnP streamer generated "most played" playlist, if I touch the three dots alongside the playlist in the App and then "play", the tracks are loaded but do not play. I have to then touch play again to start playing.
Neither of the above happened in previous versions of the Naim iOS App.
Posted on: 13 February 2017 by Claus-Thoegersen
Hi,
Do you have the app on more than one device? That could explain the  error message.
Claus
Posted on: 13 February 2017 by juanito
No, the App is only on one device
