OS Digital Mapping
Posted by: Don Atkinson on 21 February 2017
I have an i-pad mini 4 with 128Gb and cellular connection, ie it has a GPS chip.
I am planning to add OS digital mapping at 1:25,000 Explorer scale (to either save on buying yet more Explorer maps or to supplement those that I do buy).
The two sources of maps that I am considering are [the OS direct] and [Memory Map].
OS offer a "Premium" service which includes the 1:25,000 Explorer maps at £19.99 per year. Download as much and as often as you like and use off-line. With the annual subscription I presume you will always have access to the latest version of each map.
Memory Map also offers the entire UK for £150 in Standard format or £180 in High Definition format.
I tried the 1 day free trial of the Standard and HD versions from Memory Map today. I must say the detail and colour etc on both maps were every bit as good as the printed map, especially the HD version. For £180 it seems good value and the maps downloaded very quickly even from 4G as well as the internet.
My main concern with Memory Maps is, ......would I be limited to the current (2016/17) versions and would I perhaps need to spend another £180 to update the maps in (say) 5 years time or so ?
OTOH, Does the OS provide their maps in HD version, or is it just Standard definition ? Today, the Standard version loaded from Memory Map was very good, acceptable, so to speak. However, I recently downloaded a 1:25,000 OS map using the Digital Code from the OS paper version. The digital colour was "washed out" and the Rights-of-Way footpaths layer was missing, ie the footpaths were there, but the green overlay designating a Right-of-Way was missing. I wasn’t impressed.
I’m happy with the Memory Map quality, but uncertain about the update aspect.
I’m happy with the update aspect of the OS direct maps, but unsure about the quality I will obtain.
Any advice ?
Posted on: 21 February 2017 by Eloise
This is iPhone screenshot rather than iPad but do you not have something similar to this using OS Maps app?  Can clearly see the green marking from footpaths ...
Untitled Untitled
Posted on: 21 February 2017 by Don Atkinson
Hi Eloise,
thanks for the screen shots. Those look like the ones I got to try today from memory maps. Green footpaths and all.
 I'm confident that both high def and standard def maps from memory maps will be great.
however, the map I downloaded from the OS  didn't have the layer containing the green paths, just the underlying grey dashes.
are yours from the OS or memory maps ?
cheers don
Those were from OS - the OS Maps app.  There are two OS apps which are similar - the one I use has a "pointer" on a red background as an icon.
The Digital download I got from the OS was for my grandson. I will download another that happen to have. These are the free downloads you get when you buy a paper map.
are yours their Premium offering covering the whole UK for £20pa direct debit. That is what I was considering.
many thanks for helping out.
Yes the £20pa subscription.
