Upgrade to Naim XS from Rega Brio R
Posted by: Spain is diferent on 23 February 2017
I´ve just bought a XS an I hope arrives tomorrow. My present amplifier is a Brio R.
Anybody who has listen both?
What are the diferences  I´m giong to find ?
I´m quiet happy with the Brio but what I have read about XS made me buy it.
what I´m looking for is more texture, more full body sound and more present treble but but I would like no to past to the harsh line and been as enjoyable as the Brio.
Posted on: 23 February 2017 by ryder.
Perhaps you let us know once you have compared the Nait XS to the Rega Brio-R? I do not have experience with the Brio-R but have owned the Elicit MK2 (now Elicit-R Mk3) and have compared the Rega Elicit to the Nait XS in my system. The integrated amps sound quite different but the Elicit is not a Brio-R so it may not be useful to describe on the differences here.
Posted on: 24 February 2017 by joerand
Having demo'd a Brio-R and owned a Nait XS for years on the same speakers, I suspect one improvement you'll notice is a better command of your speakers with the XS. Better insight and resolution as well. The Brio-R is a VFM beginning, the Nait XS is the next level of hi-fi. Congrats.
Posted on: 24 February 2017 by Christopher_M
I hope your Nait XS gives you as much pleasure as mine gave me. I've heard and liked the Brio-R, though not compared the two directly. Please report your findings.
Chris
Posted on: 24 February 2017 by Spain is diferent
Hi all,
thanks for reply.
I will let you know diferences during the weekend because my new baby is here already.
You'll be up all night. Try to sleep when you can ;-)
C.
Posted on: 25 February 2017 by NJB
Spain is diferent posted:
Hi all,
thanks for reply.
Good luck, you should have a big smile on your face soon. However, give it time. Hifi is as much about what your ears are used to as what the system is doing. Normally, my upgrades start off as 'different', progress through 'not sure', move into 'that bit sounds good' and, hopefully, end up with 'sold, there is much more here now'.  I think the XS will take your enjoyment up a notch, and remember that it will drive your speakers differently and you might need to review their placement etc.
Posted on: 25 February 2017 by The Strat (Fender)
I love Rega stuff but I think you'll find the XS an improvement in all areas.
Enjoy.
Lindsay
Posted on: 27 February 2017 by Spain is diferent
Hi all,
I owe all of you my first impressions.
As I has read when a new device arrives your ears needs time to digest the new sound. As I know it, what I do is leave the new two or three days and then I change back to the old device. I do never compare both directly. Most of the improves are evident when you change back to the older and you find the evidences of the new improves.
Well, this is what i have made this weekend and I´am going to enumerate the differences to my ears, with my system and in my room:
-Naim Xs drives better and with more autorithy my EB Acoustics EB1 .
-As I expected treble is a little bit more open and with a little more presence.
-Shows new frecuencies in the bass that never been there before ( even crossing with a subwoofer ).
-More defined bass.
- Still listenable and never harsh.
Those are the improves
Now what I feel I have lost ( I want to insist that is in my set up )
-The bass remains a bite predominant.
-Voices are a little back.
- An attribute of the Brio partnering with the EB´s is that in some way gets a melody of every music ( even with Rage against the machine )
For me the both has a similar tonal balance and a similar way to interpretate the music. The Rega a bit mellow and Naim a bit realistic.
Dont want to loose the good things of the Rega and now I have discovered the drive and the response in the treble and in the bass i dont want to loose them too.
I must keeping trying. This week with my other bookshelves ( Quad 12L2 )
The rest of my system is:
Source : NAD 545 bee
Speaker cable: Chord Epic twin
Source cable: Atlas Hyper
Posted on: 27 February 2017 by Nuno Baptista
Rega and Naim gives both Prat, but are very different, as you will find out.You have a good system, now just enjoy it.
Posted on: 27 February 2017 by b_lund
Hi all,
-More defined bass.
I would certainly have upgraded source first making this exercise a bit pointless
Brio is a fine little amp and deserve decent signal
In your case I would have gone better source, keeping Rega amp or next up the 5si amp which is a bit more fun
Well guess this is the most common act most people focus on amp and sort of forget source
Posted on: 27 February 2017 by hungryhalibut
Yes, using an £1800 Naim amplifier with a £350 CD player isn't the approach I'd recommend either. Improving the amp with an inadequate source can actually make things worse, so I wouldn't be surprised if the Nait is not conclusively better than the Rega, which is a fine machine. If I were the OP I'd be looking for a used CD5x or 5XS.
Posted on: 27 February 2017 by Christopher_M
Maybe that's next. How would we know?
C.
Posted on: 27 February 2017 by Iconoclast
b_lund posted:
Hi all,
-More defined bass.
Apparently the new (2017) Rega Brio is a substantial improvement over the old one.
The main advantage an XS 2 will have is the capability of driving more difficult to drive speakers. The main disadvantage is that it costs three times as much.
Posted on: 27 February 2017 by joerand
Iconoclast posted:
Substantial is subjective. On paper the newer Brio-R has gained an internal HP amp. The case has been redesigned. I haven't heard the newer version, but the former was no real powerhouse as 50 watt integrateds go. Great for a happy, bouncy bookshelf system. It's more an attractive entry-level priced package with its half-case size and internal phono stage.
The Nait XS is a different league of hi-fi. Is it worth three times more money? Subjective. For me there was no contest and I spent for the XS. For a fairer comparison I'd match the various Nait 5's versus the Brios. The Naits will show better command of the speakers. Also, I've found NACA5 more involving than Chord speaker cable on Naim integrateds.
Posted on: 01 March 2017 by Spain is diferent
For sure my weak point is the CDP but I must say I was very, very happy with the sound just looked for alleviate a subtle congestion in mids and thought a better amplifier could do.
If to get what I was looking for I need to rebuild all my system my opinion is it doesn't worth.
Naim CDP´s arent cheap and I have no doubt about it quality but nobody could make sure I would get what I look for.
Im going to enjoy the XS for a few months because some recordings are more enjoyable than with my Brio and possibly I will sell it, at last I have bought it at good price.
Posted on: 01 March 2017 by Christopher_M
Does the 'it' to the Brio-R or the XS?
C.
Posted on: 01 March 2017 by MangoMonkey
If you like the Rega sound, try the apollo-R or Rega Dac combined with the nait 5i.
also - don't go to the Saturn or elicit - they just aren't as much fun.
Christopher_M posted:
C.
To the XS , but who knows.
Regards.
MangoMonkey posted:
I dont  know if  I like the Rega sound ( I owned Rs1 bookshelves and didnt like ), I like the sound I have now with the Brio. I´ll think about to match with new sources but is no my first idea.
Thnaks.
C.
Regards.
Thanks. Looking at my own contribution again, I realised that with the missing word refer after 'it', my  grammar was pretty ropey.
Regards, C.
one thing though - your brain needs time to acclamatize itself to the different sound signatures. Once you get used to naim, you will find Rega boring.
the worst thing you can do is keep switching back and forth ...
Posted on: 01 March 2017 by Joppe
Congrats! I think you will warm towards the Naim sound with more time. If you don't really get there with more time, try to borow an RCA-Din cable before selling the amp. I have many times been surprised by the changes using din can have in a Naim system.
Posted on: 03 March 2017 by Spain is diferent
MangoMonkey posted:
Thanks, Is what Im going to try because I would like to keep some features of the XS, but the Brio R isn´t boring, believe me.
Found an Arcam Alpha 10 with DAVE module in a good price ( 250 Pounds). I really liked the DAC and plenty of power but boring, then I prefered a NAD 326bee.
Posted on: 03 March 2017 by b_lund
I believe you have been much better off getting a Rega Apollo cd player to match your Brio
Next step could be a 5si amp or the new 2017 Brio
Reason you didn't like the RS1 could be they are extremely revealing, what they told you might have been signature of a crap source
Isn't it a wonderfull game !
