Remote for 552
Posted by: fathings cat on 26 February 2017
hi folks, hopefully a quickie! What remote can I sue with a 552 (please exclude r com)
my used 552 didn't come with one.......
Gary
Use not sure!
I think any of the remotes but some are easier to use than others. I like the narcom 4, the 3 I think is horrible and the 5 is aimed at streamers but is usable. The r-com my wife thinks will scratch the table and has banned it from the living room.
The standard remote that comes with the CD players and pre-amps work fine with the 552. Even though I have the R Com - a nice weighty beast - I find I still prefer to use the Narcom that came with my CDX2.2, which also has numbered buttons to select tracks so has more functionality than the R Com.
I use the Narcom 3.I think it came with my Nat5. Have a Narcom 4 but never got round to using it. Also have the R-com that came with my 552. Did you get a discount for not having the R-com with the 552. It's quite expensive. Good looking bit of bling, but limited functionality. Mines in the cupboard. Pity the Flash had to be discontinued. EC regulations I think.
Narcon is cheap to replace, I think. Worth having. Same remote comes with NACs, CD, and NAT. Since you have the NDS, it has a better remote than Narcon 4/5. Or use an iPhone etc.
Did you replace your 252/NDX with the 552/NDS? Or do you have both systems? The remotes are the same -- the Rcom is an extra bonus -- you still get a Narcon with 552.
Nick
I like the Flash remote, which came with earlier NAC552s.
The 552 is an early one so no r com and when I sold my 252 I was obliged to include the remote. I think I'll only use it to programme the inputs as I do everything else with I pad. Was planning on searching the usual places but wanted to check which one would do the 552 inputs?
cheers
Gary
ps I went from NDX / NDac / 555 to NDS and then a 552 came up locally which I couldn't refuse. - although it's currently heading backwards to HQ for a once over (no Dr yet though...)
Cheers Gary. I guess I never tried programming the 552 using my NDX remote. Once set up, I prefer the NDX remote to the Narcon.
Nick
Where can i get my flash fixed?
Sorry: Narcom, not Narcon.
Narcom 4, although i' ve been told that has been replaced by Narcom 5 and is now the only one available like replacement part.
Roberto
Dev B posted:Where can i get my flash fixed?
Dev, what's wrong with it? It could just be batteries - if you don't snap the last one in cleanly then it can act all dead. Let the capacitor discharge for a bit and then try again.
I'd second trying to get hold of a Flash. The Narcom is horrible by comparison...
