The IEC fuse holders are easily accessed using the gentle persuasion of a small screwdriver : )
In our village, we get little power-cuts two or three times a year, and one never knows when they will happen, but they usually do in the evenings, and each & every time the power-cut lasts around 5 - 10 seconds. If this happens in hours of darkness [which they usually do] the lights go out leaving the room pitchy black dark, no chance to get to the naim kit to switch-off or pull the plugs before the power comes back on again, however, in all the years it's been happening, these little power-cuts and back-on agains have never blown any fuse anywhere, and the only IEC fuse blowing drama i've ever experienced is when i switch my NAP500 on.
It would seem the occasionally blowing of my NAP 500 fuse only happens when powering it back on after a switch off, but the power-cuts from the grid always appears to be completely harmless.
I can only assume the blowing of my NAP 500 fuse is something to do with the switch getting pushed on the 500PS.
