Garden solar lights
Posted by: JamieWednesday on 03 March 2017
Just a quick request.
Has anyone come across any pillar/post type, solar powered lamps that actually work in British weather? I.E. with no sunshine.
Thank you.
Posted on: 03 March 2017 by Tony Lockhart
Do solar powered lights work with no solar energy?
lol.
Posted on: 03 March 2017 by sheffieldgraham
JamieWednesday posted:
Thank you.
I once had some that had integral rechargeable batteries. The sunlight would top them up. Maybe worth a look for something similar. Trouble was they weren't very bright (LED type). Maybe things have improved.
Posted on: 03 March 2017 by BigH47
Our neighbours have a selection of solar lights, they seem to work all year, not sat up all night to see how long the winter charge is, they are alight when I go to bed. As mentioned above I haven't seen any that actually throw a huge amount of light about.
Obviously they have some form of battery in them, not a  lot of point only having them on only when it's light.
Posted on: 04 March 2017 by Deeg1234
We have some kodiak lights from solarcentre. They are working happily currently from dusk until about midnight, longer during summer.
Posted on: 04 March 2017 by Bert Schurink
I haven't seen so far ones who last longer. They tend to break easily. If you want to have reliable light stay on normal electricity ones.
Posted on: 04 March 2017 by bicela
Thank you.
Theoretically yes, but with the actual solar technology you have to use a battery and a quite large collection surface. In lamps, even led, this surface becomes too large from practical and aesthetically point of view, additionally the solar caption surface is static (not follows the best position withn the maximum exposition during seasons and daylight). Producer need so to made a trade-off between cost and a compact design that results in non optimal performance.
In my garden I so opted for wired led waterproof illuminations.
Even if here in Italy we have a different (someone would consider better) weather!
Regards. Maurizio
Posted on: 05 March 2017 by Mike-B
If you want them to make the garden look 'pretty' at night,  OK  but the problem is they're not very bright & for illuminating a path or steps (& thats what I was trying to do)  you need a number of them.  Battery light time is OK - mine lasted long enough for an evening in the garden & went past midnight.  Talking to others, the general feeling is they are not robust & do have a limited life,  it seems the common fault is PV panel reliability, battery life gets shorter over time & eventually for whatever reason they conk out.     When mine expired I didn't bother to replace them (we survived the last 3 years without them).    I'm having some serious groundwork done this year & will install 12vDC power to some more robust wall & post fitted lights.
