HDX to HDMI
Posted by: SteveHathway on 11 March 2017
Hi guys, can I send the vga signal from my HDX and send it to my HDMI tv? And how please?
Thanks Steve
Posted on: 11 March 2017 by Cbr600
Steve, I believe the vga connection is intended for use to connect to a. Tv, so you Can use the tv as a monitor when using the nserve software,
Posted on: 11 March 2017 by blythe
Do TV's have a VGA connection these days?
Posted on: 11 March 2017 by SteveHathway
No that's why I want to convert it to HDMI
Posted on: 11 March 2017 by Richard Dane
I think you'll need a convertor box.
Posted on: 12 March 2017 by sktn77a
If the TV doesn't have a VGA (computer) input socket, then you will need a VGA to HDMI converter.  Check them out on ebay.
