Connecting Two Lengths of A5, and some other questions...
Posted by: Naimthatune on 15 March 2017
Evening all. Just looking for some advice on cabling. Anyone ever joined a couple of A5 cables? If so, what method, and did it affect the sound quality at all? I'm in the middle of a remodel and need about 25 to 30ft of cable run. There are a few pre-owned options out there which would help me keep the cost down, but none that length unless I join them!
Secondly. Has anyone ever run their A5 (or similar) into the back of a base board (skirting board) via a male/female connector so they could use their speakers, and then disconnect them for convenience? ( we rent the place sometimes & system is in AV closet out of sight.). If so, what was the termination used?
Finally. If the above is possible, would it be feasible to run a spur off the back of base board above, and repeat this in the room directly above so that the speakers could be used in that room ?( not at the same time obviously) That would add 10ft to the overall run.
I'm thinking 272 and 250.2 type system, mainly streaming from NAS etc... Speakers tbd.
Really appreciate any help on this.
Thanks.
