which cable for XLR balanced (external dac) to DIN or RCA?
Posted by: Manu68 on 24 March 2017
HI,
what is the best way to connect my external DAC with XLR balanced output to my nac 272 preamp?
XLR to DIN 5 or XLR to RCA (if it matters anyway)?
and which cable would you recommend that is good value for money?
thanks
Posted on: 24 March 2017 by hungryhalibut
I believe you should use the dac's unbalanced output as the 272 does not have balanced inputs. So phono or din.
Posted on: 24 March 2017 by Huge
Use the DIN input on the 272, however as HH says use an unbalanced output from the DAC if it has one (if not you'll need a specially made cable).
Good value for money would be to get someone to make a cable from Mogami W2549 (or Canare L4-E6S).
Posted on: 24 March 2017 by Manu68
thanks guys. Is it possible to find a RCA to DIN 5-pin cables?
Posted on: 24 March 2017 by james n
may be useful
never heard. Can you eat it?
thanks
Posted on: 24 March 2017 by Richard Dane
For best value look for a second-hand Chord Chrysalis RCA-DIN5 interconnect - ideal for Naim and not expensive. There are usually plenty around in the usual places.
Manu68 posted:
thanks
Google it and find out
Posted on: 24 March 2017 by ianrobertm
Richard Dane posted:
Currently, one is available... in Denmark. OK, its DIN4, not DIN5 - not insurmountable. Price might not be considered best value, though.
got it, chord cable it will be, saw the one you mentioned from DK as well...
[@mention:69426746497974136] - Lols. Price is silly - IMHO.....
[@mention:1566878604014594] thanks for the tip
I will continue looking...
[@mention:69426746497974136] - When new, Chord Chrysalis cables cost around GB£30 to £40. Its seems that since then, they have attained some sort of 'mythological' status....!! With associated prices.
Flashback Sales will make you exactly what you want if you can't find any in the usual places. Dave is very helpful and quality is first class.
would going to higher end cables from Chord such as Shawnline significantly change HQ or was it so that the Chord Chrysalis deemed best value for money?
[@mention:1566878603926433] thanks a lot for the tip, will contact him now!
ianrobertm posted:
Really ? - i'll have to look through my 'better keep it, it may come in handy one day' cable box. I'm sure i've got one back from the days when Chord cables looked hand made
