Nac282/ headline
Posted by: Richard archbold on 29 March 2017
first of 2 questions 1st since I now have my nac282 supercapped can I use the aux2 for my headline?
No. That would create an earth loop an impair overall system performance. The Headline requires a dedicated power supply and a NAPSC works just great here, so don't spoil the ship etc..
Second question?
Thought as much Richard... just wanted to be sure
thanks
You clearly need another Supercap ![]()
NAPSC on my Headline does a fine job.
Hi Richard, so using HCDR doesn't create an earth loop with headline?
Why does Supercap create an earth loop?
[@mention:69004037368204356] - The SuperCap does not create an Earth Loop. Its plugging a Headline into Aux2 that does that. The Headline needs a separate Power Supply - like say a NAPSC, or a HiCap.
It doesn't .. it's when you plug a napsc into aux2 of the nac282 it creates an earthing loop
OK i'm confused. I think you can plug stageline into Aux 2, but not headline.
You can power a Stageline from aux 2, but not a headline. As has been said before, the headline needs its own power supply. Simple.
Sigh.... The Aux2 powered output on the 'big' Naim Pre Amps is deigned & intended to power either a StageLine or a PreFix, I believe.
Richard archbold posted:It doesn't .. it's when you plug a napsc into aux2 of the nac282 it creates an earthing loop
Since when would anyone want to plug a NAPSC into the AUX2 of a 282 !!?
sheffieldgraham posted:Richard archbold posted:It doesn't .. it's when you plug a napsc into aux2 of the nac282 it creates an earthing loop
If you managed that, I think you'd create a bit more than an earth loop! I was thinking an exploding sausage might be in order, but it would be bad form for me to use it twice in the same day!
I think Richard A mean't to type NAHA in his post rather than NAPSC..
Sorry I meant the headline
