POE network switch
Posted by: rohan on 02 April 2017
Been running streaming to nac 272/250dr/xps/dr over a devolo dlan homeplug solution . wanted to see if direct cabling from my router which is upstairs improves SQ , and i must say there was a noticable improvement.(Had to run a 30m cable) Due to the distance and number of rooms requiring network cabling and wifi through an AP, ( a couple of network streamers for TV and the synology, )the installer is recommeding the use of an 8 port switch with .p.o.e
Am I wrong in thinking that the introducttion of the poe defeats the purpose as it is also likely to introduce interference if connected to the 272
Best to go with a non poe option and power the wirless AP upstairs explicitly from the wall?
Any experiences?
